Bottoms of Checkboxes are Cut Off
Postby BlackHat » Mon Jul 13, 2009 12:26 pm
In my CheckBoxTree I am getting a problem where the very bottom of the checkBox is not visible. If anyone can help me fix this I would very much appreciate it.
BlackHat
Re: Bottoms of Checkboxes are Cut Off
Postby JIDE Support » Mon Jul 13, 2009 12:28 pm
Can you please give us more information or share with us your test case? We tried our CheckBoxTreeDemo which has a huge list and we could not notice the issue you mentioned.
Postby BlackHat » Mon Jul 13, 2009 1:01 pm
I attached an image of the problem... As you can see the bottom of every check box is cut off.
BlackHat
Postby JIDE Support » Mon Jul 13, 2009 1:13 pm
Looks like this is a row height issue from the image you post. Please try invoke CheckBoxTree#setRowHeight() and see if it could solve your issue. If it does, please try debug to see if you invoke that method anywhere else. We would have to ask for a test case if you didn't invoke that method at all and get this issue.
Postby BlackHat » Tue Jul 14, 2009 8:03 am
Thank you very much, that fixed it
BlackHat
Users browsing this forum: No registered users and 83 guests
