by RajaRajeswari_V » Mon Jul 13, 2009 10:47 am
I have one problem while using the checkbox tree.. is there any way to not dispaly the check box for the tree root node. for example
Root
child1
chldd2
child3
i want to show the check box for the childs only but not the root node.. is thery any way to do this please advice
RajaRajeswari_V
by JIDE Support » Mon Jul 13, 2009 11:20 am
Please try use JTree#setRootVisible(false).
by RajaRajeswari_V » Tue Jul 14, 2009 11:54 am
it is not displaying the root node also.but i want to dispaly root node without check box..please help me out
RajaRajeswari_V
by JIDE Support » Tue Jul 14, 2009 4:58 pm
Please try override CheckBoxTree#isCheckBoxVisible() with the following line.
- Code: Select all
return path.getPathCount() != 1;
by sbrattla » Thu Jul 16, 2009 2:40 am
That's what i did too:
- Code: Select all
public class KeywordCheckBoxTree extends CheckBoxTree {
public boolean isCheckBoxVisible(TreePath path) {
if (path.getLastPathComponent() instanceof Keyword) {
return true;
sbrattla
