How to insert node using FilterableTreeModel
Postby ismail_mca » Sat Jul 04, 2009 11:35 am
I've implemented searchable menu tree using model as FiltrableTreeModel.
Per new requirement,we want ti implement Drag and Drop facility to the same Searchable Tree.
Since FiltrableTreeModel doesnt have methods like insert/remove node methods.So,we cant implement Drag and Drop.
Is there way to inser/remove node using FilterableTreeModel ?
(Its not possible to use model as DefaultTreeModel in place of FilterableTreeModel as we need searchable option)
Please help me.
ismail_mca
Re: How to insert node using FilterableTreeModel
Postby JIDE Support » Sat Jul 04, 2009 3:30 pm
Since FilterableTreeModel is just a model wrapper, it just reflects the records in original data model after filtering. So we don't have a plan to implement insert/remove interfaces like DefaultTreeModel does.
To achieve your goal, please try change the original tree model accordingly while drag and drop happens then fire proper tree node remove/insert/change event. FilterableTeeModel will notify the update to the JTree as well. With these steps, JTree will update the UI just like you want, removing the node from the start dragging position and inserting the node to the target position.
Users browsing this forum: No registered users and 83 guests
