MenuItem Icon Alignment Problems
Postby rwhittak3 » Mon Jun 15, 2009 4:11 pm
I have a menu that has 2 items, a normal menu item, and a submenu (JMenu). Both the menu item and the submenu have icons. When I apply the Jide extensions, the icons fail to line up. Here is some sample code.
public class MenuItemIconAlignmentTest extends JFrame {
    public MenuItemIconAlignmentTest() {
        } catch (Exception e) {
            e.printStackTrace();
        JMenuBar bar = new JMenuBar();
        JMenu menu = new JMenu("Menu Bar");
        JMenuItem item = new JMenuItem("Menu Item");
        item.setIcon(new ImageIcon("green_circle.png"));
        JMenu submenu = new JMenu("Submenu");
        submenu.add(new JMenuItem("Submenu Item"));
        submenu.setIcon(new ImageIcon("green_circle.png"));
        menu.add(item);
        menu.add(submenu);
        bar.add(menu);
        setJMenuBar(bar);
        setSize(200,200);
        setVisible(true);
    public static void main(String a[]) {
        new MenuItemIconAlignmentTest();
When I run it, I get something that looks like this:
You can see that the submenu's icon offset to the right, butting up against the edge of the sidebar. Is there something I can do to line those icons up properly?
Thanks in advance for any help or advice!
Richard
rwhittak3
Re: MenuItem Icon Alignment Problems
Postby JIDE Support » Mon Jun 15, 2009 6:21 pm
It's weird. I cannot reproduce the issue you mentioned. Since I don't have the img file, the img icon is the only place I changed from your test case.
        item.setIcon(ButtonsIconsFactory.getImageIcon(ButtonsIconsFactory.Buttons.RENAME));
        submenu.setIcon(ButtonsIconsFactory.getImageIcon(ButtonsIconsFactory.Buttons.RENAME));
        menu.add(item);
        menu.add(submenu);
        bar.add(menu);
        setJMenuBar(bar);
        setSize(200,200);
        setVisible(true);
Below is the screen shot.
Postby rwhittak3 » Tue Jun 16, 2009 8:29 am
Huh, that is weird. I didn't think the image would be the difference, but perhaps it is.
Anyways, if you could try it with my image, that would be great!
[download link removed]
Thank you for looking at this issue.
Richard
rwhittak3
Postby rwhittak3 » Tue Jun 16, 2009 8:32 am
Oh, also, I should mention that I'm running on Windows XP.
rwhittak3
Postby JIDE Support » Tue Jun 16, 2009 8:32 am
I guess maybe the release did the trick. We checked the history and looks like one fix in 2.6.6 could have fixed the issue. Would you please give our latest 2.6.6 a try?
Postby rwhittak3 » Tue Jun 16, 2009 9:00 am
The icons line up properly with the latest version. Thank you very much for looking into it!
rwhittak3
Postby EikeB » Tue Jun 23, 2009 8:43 am
it seems to me, that i have a similar problem with the Swing menu items.
I build a GUI with Netbeans with some JMenus and JMenuItems.
(This is a screenshot how it looks like before executing any jide stuff)
In another FrameI use the ListDataIntelliHints, here is the code:
intellihints = new ListDataIntelliHints(programNumber, ProgramManager.getProgramList("",""));
intellihints.setCaseSensitive(false);
(programNumber is a JTextfield)
After executing these two lines the appearance of all my JMenus change somehow. (in all Frames)
I used jide-oss-2.5.8:
With upgrading to version 2.6.6:
Any suggestions how to solve this problem?
EikeB
Postby JIDE Support » Tue Jun 23, 2009 8:59 am
Please try invoke LookAndFeelFactory.installJideExtension( LookAndFeelFactory.VSNET_STYLE_WITHOUT_MENU) explicitly before you invoke the two line of codes and see if it solves your issue.
Postby JIDE Support » Tue Jun 23, 2009 10:07 am
It would be great if we can have a test case from you regarding this issue. We don't expect to impact the icon display anyway even you install the entire look and feel.
Postby EikeB » Tue Jun 23, 2009 12:43 pm
I just uploaded a small program that shows the "bug".
But adding the line:
LookAndFeelFactory.installJideExtension( LookAndFeelFactory.VSNET_STYLE_WITHOUT_MENU);
has solved the problem.
IntelliTestCase.zip
(146.3 KiB) Downloaded 2288 times
EikeB
Postby JIDE Support » Tue Jun 23, 2009 1:20 pm
Thanks for your attempt to share. However, we do need source code when we talk about test cases so that we can debug it. The code fraction that could demonstrate how you create the menu items would be good enough.
Postby EikeB » Tue Jun 23, 2009 2:42 pm
Sry, thougt i uploaded the sourcecode... here is it ;)
Its just the source, I couldnt upload the whole project, filesize was greater than 256k :?
IntelliTestCase_src.zip
(99.63 KiB) Downloaded 2244 times
EikeB
