CheckBox Tree
CheckBox Tree
Postby jamindhar » Mon Jun 01, 2009 10:16 pm
in Check Box Tree how can we check whether a particular node is selected or not?
and how can we get the selected child information for a parent..
for example Parent1 has two childs ,child1 and child2 .. how can i get the selected child information by using parent node..
Please help me out..thanks in advance
Krishna Kumar Hotha
jamindhar
Re: CheckBox Tree
Postby JIDE Support » Mon Jun 01, 2009 10:52 pm
You can call checkBoxTree.getCheckBoxTreeSelectionModel() to get the selection model which tells you which tree path(s) are selected.
Re: CheckBox Tree
Postby jamindhar » Mon Jun 01, 2009 11:01 pm
hi,
i used
selectedElements.getCheckBoxTreeSelectionModel().getSelectionPaths() method to get the all selectionpaths.. but i need the information about particular parent..i.e
is there any method which will give you the information about selected chidls by taking parent node..?
and
is there any method which will tell you a particular node is selected or not?
Krishna Kumar Hotha
jamindhar
Re: CheckBox Tree
Postby JIDE Support » Mon Jun 01, 2009 11:21 pm
That's all the APIs we provided. You can use TreePath API to get where you want.
