JideTabbedPane :: NPE when using WRAP_TAB_LAYOUT policy
Postby apavlik » Fri May 15, 2009 4:49 am
Sorry if this is not the right place to ask.
I've got a problem using JideTabbedPane (2.5.1) with tab layout policy set to WRAP_TAB_LAYOUT.
Here is a sample app:
import java.awt.BorderLayout;
import javax.swing.JTabbedPane;
import javax.swing.SwingUtilities;
import com.jidesoft.swing.JideTabbedPane;
public class TabbedPaneTest extends JFrame
    public TabbedPaneTest()
        super("tabs test");
        buildUI();
    private void buildUI()
        JPanel content = new JPanel(new BorderLayout());
        JideTabbedPane tabs = new JideTabbedPane();
        tabs.addTab("tab 1", new JPanel());
        tabs.setTabLayoutPolicy(JTabbedPane.WRAP_TAB_LAYOUT);
        tabs.setTabShape(JideTabbedPane.SHAPE_EXCEL);
        content.add(tabs, BorderLayout.CENTER);
        getContentPane().add(content);
        setSize(300, 300);
        setDefaultCloseOperation(EXIT_ON_CLOSE);
    public static void main(String[] args)
        SwingUtilities.invokeLater(new Runnable()
            public void run()
                TabbedPaneTest test = new TabbedPaneTest();
                test.setVisible(true);
An exception is thrown when I start the app:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
   at com.jidesoft.plaf.vsnet.VsnetJideTabbedPaneUI.paintContentBorderTopEdge(Unknown Source)
   at com.jidesoft.plaf.basic.BasicJideTabbedPaneUI.paintContentBorder(Unknown Source)
   at com.jidesoft.plaf.basic.BasicJideTabbedPaneUI.paint(Unknown Source)
   at javax.swing.plaf.ComponentUI.update(ComponentUI.java:143)
   at javax.swing.JComponent.paintComponent(JComponent.java:763)
   at javax.swing.JComponent.paint(JComponent.java:1027)
   at javax.swing.JComponent.paintChildren(JComponent.java:864)
   at javax.swing.JComponent.paint(JComponent.java:1036)
   at javax.swing.JLayeredPane.paint(JLayeredPane.java:564)
   at javax.swing.JComponent.paintToOffscreen(JComponent.java:5129)
   at javax.swing.BufferStrategyPaintManager.paint(BufferStrategyPaintManager.java:277)
   at javax.swing.RepaintManager.paint(RepaintManager.java:1217)
   at javax.swing.JComponent.paint(JComponent.java:1013)
   at java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback.java:21)
   at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:60)
   at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:97)
   at java.awt.Container.paint(Container.java:1780)
   at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:814)
   at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:714)
   at javax.swing.RepaintManager.seqPaintDirtyRegions(RepaintManager.java:694)
   at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(SystemEventQueueUtilities.java:128)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
The sample code works fine if I change line
to
tabs.setTabLayoutPolicy(JTabbedPane.SCROLL_TAB_LAYOUT);
Would appreciate any input on the issue...
ps. My PC's running Ubuntu 9.04 (Java(TM) SE Runtime Environment (build 1.6.0_13-b03))
apavlik
Re: JideTabbedPane :: NPE when using WRAP_TAB_LAYOUT policy
Postby JIDE Support » Fri May 15, 2009 8:48 am
It is expected, JideTabbedPane doesn't support WRAP_TAB_LAYOUT. It only supports SCROLL_TAB_LAYOUT. We don't plan to support WRAP_TAB_LAYOUT for the moment.
Postby laurentapo » Fri Sep 17, 2010 4:46 am
Did you plan to support WRAP_TAB_LAYOUT on JideTabbedPane ?
Thanks for your response
Laurent
laurentapo
Postby JIDE Support » Fri Sep 17, 2010 9:10 am
So far we still don't have a plan to support it yet.
Users browsing this forum: No registered users and 75 guests
