Any changes done to the selectNone() method of CheckBoxList
Postby RajaRajeswari_V » Tue May 12, 2009 6:23 am
Hi
In my code i have used the Objects of CheckBoxlist and use the code in the following way
diagramsOtherLinksCheckBoxList.selectNone(); this is using the old jide jars
Now i am using the latest evaluation version of Jide. using the latest jars, the code compiles well but in Run time it is giving the following error
Exception occurred during event dispatching:
java.lang.IndexOutOfBoundsException: bitIndex < 0: -1
at java.util.BitSet.get(Unknown Source)
at javax.swing.DefaultListSelectionModel.clear(Unknown Source)
at javax.swing.DefaultListSelectionModel.setState(Unknown Source)
at javax.swing.DefaultListSelectionModel.removeIndexInterval(Unknown Source)
at com.jidesoft.swing.CheckBoxList.selectNone(Unknown Source)
i wanted to know if there is any implementation differnce in the selectNone() method of CheckBoxList and an alternate way to deal with this.The java doc supplied doesnt mention anything about it though.
Rajeswari
RajaRajeswari_V
Re: Any changes done to the selectNone() method of CheckBoxList
Postby JIDE Support » Tue May 12, 2009 9:03 am
Please check if the size of the model is 0. We will add a validation check here in next release.
Postby JIDE Support » Sat May 16, 2009 6:01 pm
Just so you know, this is fixed in 2.6.3 which was just released.
