Replacement method
Replacement method
Postby RajaRajeswari_V » Wed May 06, 2009 3:11 am
Hi
i am sorry if this question appears to be silly. Wanted to know which is the replacement method for getSelectedObjects() method of com.jidesoft.swing.CheckBoxList class.In the old versions of Jide-common.jar, in the documentation they have mentioned that getSelectedObjects is different from getSelectedValues() which comes from the superclass JList.
Earlier in my code i used
checkBoxListObject.getSelectedObjects();
Now i m using
checkBoxListObject.getCheckBoxListSelectedValues();
Both these methods return a object [] . but not sure if they return same elements. Please clarify
Rajeswari
RajaRajeswari_V
Re: Replacement method
Postby JIDE Support » Wed May 06, 2009 9:08 am
Yes. You are correct. getCheckBoxListSelectedValues() is the right method to replace getSelectedObjects().
