PageNavigationBar with cellrender and remove column
Postby maraneda » Fri Apr 17, 2009 10:05 am
Hi
I'm using a JideTable with PageNavigationBar:
tblNews.setModel(tableModelNews);
tblNews.getColumnModel().getColumn(1).setCellRenderer(new ButtonCellRender());
tblNews.getColumnModel().removeColumn(tblNews.getColumnModel().getColumn(0));
PageNavigationBar navigationBar = new PageNavigationBar(tblNews);
this.add(navigationBar,BorderLayout.SOUTH);
scroll.getVerticalScrollBar().addAdjustmentListener(new AdjustmentListener() {
public void adjustmentValueChanged(AdjustmentEvent e) {
tblNews.setCellContentVisible(!e.getValueIsAdjusting());
scroll.addComponentListener(new ComponentAdapter() {
public void componentResized(ComponentEvent e) {
int rowCount = scroll.getViewport().getHeight() / tblNews.getRowHeight();
PageNavigationSupport pageNavigationSupport = (PageNavigationSupport) TableModelWrapperUtils.getActualTableModel(tblNews.getModel(), PageNavigationSupport.class);
if (pageNavigationSupport != null) {
pageNavigationSupport.setPageSize(rowCount);
I'm using a custom CellRendes and i want to remove a column too.
but when i run the application, it doesn't show my custom cellRender and doesn´t remove the column. Is there a trick to do this or it's a bug?
maraneda
Re: PageNavigationBar with cellrender and remove column
Postby JIDE Support » Fri Apr 17, 2009 10:08 am
That's strange. PageNavigationBar shouldn't have such a side effect as you described. Could you please create a complete test case for this bug report so that I can compile and run to see the issue?
Users browsing this forum: No registered users and 67 guests
