by aidarko » Fri Apr 17, 2009 5:49 am
I'd like to ask how to set a value of a fixed size when I use RESIZE_MODE_FIXED property?
In guide wrote: "RESIZE_MODE_FIXED: All tabs have a fixed size which you can define it yourself.". But I can't find it anywhere, where to define it.
aidarko
by JIDE Support » Fri Apr 17, 2009 7:22 am
The javadoc mentioned it. Here you go.
- Code: Select all
* A tab resize mode. All tabs will be at a fixed width. The fixed width is defined as UIDefault
* "JideTabbedPane.fixedStyleRectSize" which is an integer.
public final static int RESIZE_MODE_FIXED = 3;
by aidarko » Fri Apr 17, 2009 11:21 am
In simple way, I mean how to get all tabs minimized. By customization?
aidarko
by JIDE Support » Fri Apr 17, 2009 12:50 pm
What do you mean "get all tabs minimized"?
Users browsing this forum: No registered users and 66 guests
