Question about FolderChooser delete directory
Postby ericam33 » Thu Apr 02, 2009 10:38 am
I've noticed that if i use folderchooser to create a new folder, i can delete this new one with the file system performing a delete.
If i select an existing folder and delete it, it is removed from the folder chooser but refresh brings it back and this delete is no performed on the file system.
Can i ask if this is by design or maybe a small bug?
erica
ericam33
Re: Question about FolderChooser delete directory
Postby JIDE Support » Thu Apr 02, 2009 2:01 pm
Yes. This is a bug. We will fix it in next release.
Postby JIDE Support » Tue Apr 14, 2009 8:27 pm
Just so you know, this is fixed in 2.6.0 which was just released.
Postby Graham_Allan » Wed Apr 15, 2009 1:09 am
Is it possible to disable the delete function?
Graham
Graham_Allan
Postby JIDE Support » Wed Apr 15, 2009 9:48 am
It is defined in FolderToolBar which is open source at https://jide-oss.dev.java.net/. You can disable or remove the delete button by yourself for now.
We will provide an easier way to disable or remove the delete button later on.
Postby JIDE Support » Fri Apr 17, 2009 9:45 pm
Just so you know, this feature is added in 2.6.1 which was just released. A new setAvailableButtons method is added to FolderChooser to allow you to set any buttons visible.
Postby Graham_Allan » Mon Apr 20, 2009 12:29 am
Thanks guys
Regards
Graham
Graham_Allan
