TableHeaderPopupMenuInstaller
Postby Humberto Padget » Mon Mar 30, 2009 4:30 pm
Hi
I'm using a JideTable with TableHeaderPopupMenuInstaller:
TableHeaderPopupMenuInstaller installer = new TableHeaderPopupMenuInstaller(tblAlarms);
installer.addTableHeaderPopupMenuCustomizer(new AutoResizePopupMenuCustomizer());
installer.addTableHeaderPopupMenuCustomizer(new TableColumnChooserPopupMenuCustomizer());
I'm using custom CellRendes and CellEditors too.
So, when i press "Reset to Default " in the popup menu , its remove all my custom renders & editors. Is there a trick to remove this option?
Humberto Padget
Re: TableHeaderPopupMenuInstaller
Postby JIDE Support » Mon Mar 30, 2009 5:12 pm
We will change the behavior when you select this menu item.
For now, you can extend TableColumnChooserPopupMenuCustomizer and override customizePopupMenu() to remove the menu item with name as CONTEXT_MENU_RESET_COLUMNS. You can see javadoc for that method to get more detail help.
Postby JIDE Support » Thu Apr 02, 2009 4:00 pm
After second thought, may I ask how you set your cell renderer and editor? If you use CellRendererManager and CellEditorManager as stated in our documents, it should not happen. Or you just set it to the TalbeColumnModel directly?
Postby Humberto Padget » Thu Apr 02, 2009 5:02 pm
i just set into TalbeColumnModel directly.
i will use CellRendererManager and CellEditorManager then
Humberto Padget
Postby JIDE Support » Tue Apr 14, 2009 8:31 pm
Just so you know, this is fixed in 2.6.0 which was just released. We will keep your column in this case so that your settings won't get lost.
