CellStyleTable & defaultRowSorter
Postby Humberto Padget » Tue Mar 17, 2009 7:51 am
I'm using "CellStyleTable" with "setAutoCreateRowSorter(true)", i just want default JTable's behavior for sort, but doesn't work.
I've a "CustomTableModel" who extends from "AbstractTableModel" then when i delete and add data, especially when delete, your grid try to get data of missed indexes then an NullPointerException appears.
That occurs only when is sorted.
If i put a JTable instead of "CellStyleTable", it works fine.
When i insert data into model, i add a group of data and i call to fireTableDataChanged(). That must be sufficient to update all.
Am i doing something wrong?
Humberto Padget
Re: CellStyleTable & defaultRowSorter
Postby JIDE Support » Tue Mar 17, 2009 9:26 am
Could you please create a test case for this bug report so that I can reproduce it?
Postby Humberto Padget » Tue Mar 17, 2009 11:18 am
I append a simple test. (it's a Netbeans 6.5 Project, i didn't include jide-common.jar, jide-grids.jar)
There are two tables, CellStyleTable and JTable, only CellStyleTable have anormal behavior when modify data on sorted table.
I use Java jdk 1.6.0_10.
TestCase.rar
test case
(19.56 KiB) Downloaded 2650 times
Humberto Padget
Postby Humberto Padget » Wed Mar 18, 2009 4:48 pm
Did you can reproduce it?
The error it happens when there are many deleted rows .. for example this random sequence:
Num New Rows : 27
Num New Rows : 186
Num New Rows : 272
Num New Rows : 11
Exception in thread "AWT-EventQueue-0" java.lang.ArrayIndexOutOfBoundsException: Array index out of range: 26
        at java.util.Vector.get(Vector.java:694)
        at cl.bcs.test.model.CustomTableModel.getValueAt(CustomTableModel.java:51)
        at javax.swing.JTable.getValueAt(JTable.java:2695)
        at javax.swing.JTable.prepareRenderer(JTable.java:5712)
        at com.jidesoft.grid.JideTable.prepareRenderer(Unknown Source)
        at com.jidesoft.grid.CellStyleTable.prepareRenderer(Unknown Source)
        at com.jidesoft.plaf.basic.BasicJideTableUIDelegate.paintCell(Unknown Source)
        at com.jidesoft.plaf.basic.BasicJideTableUIDelegate.a(Unknown Source)
        at com.jidesoft.plaf.basic.BasicJideTableUIDelegate.paint(Unknown Source)
        at com.jidesoft.plaf.basic.BasicJideTableUI.paint(Unknown Source)
        at javax.swing.plaf.ComponentUI.update(ComponentUI.java:143)
I discovered another problem... must be the same.
If i select sort on one column when table don't have data and i add data, then CellStyleTable don't show data but JTable do it.
Humberto Padget
Postby JIDE Support » Wed Mar 18, 2009 4:49 pm
I reproduced it and fixed it. It will be included in a release this week. I will let you know when we release it.
Postby JIDE Support » Thu Mar 19, 2009 8:26 am
Just so you know, we just released 2.5.7 which should fix the bug.
