Custom JideTabbedPane UI
Postby andy08 » Sun Feb 08, 2009 6:51 am
I'd like to custom JideTabbedPane UI especially in the TabArea.
For example,
1.use an icon paint the different state of the TabCloseButton
2.make the selected Tab don't paint focus
So,in this case,do you have any suggestion to custom UI?
Do you think it's better to add these features into next release?
andy08
Re: Custom JideTabbedPane UI
Postby JIDE Support » Sun Feb 08, 2009 11:17 am
JideTabbedPane is open source as part of JIDE Common Layer so I suggest you take a look at the BasicJideTabbedPaneUI source code yourself and see if it can be changed to do the things you want. If the feature is useful for other people, feel free to check them in.
Postby usp » Sun Feb 13, 2011 11:11 pm
For UI changes in buttons related to tabbed pane header, change paintComponent(Graphics g) method in NoFocusButton inner class which is in JideTabbedPane .
This was done successfully for my requirement.
usp.
usp
