DateSpinner setStart setEnd swing bug
Postby kcieniuch » Mon Feb 02, 2009 9:27 am
I have problems with DateSpinner that have date bounds set using setStart setEnd methods of SpinnerDateModel
here is code
     DateSpinner  timeSpinner = new DateSpinner("HH:mm:ss");
     timeSpinner.setAllowsInvalid(true);
     ((SpinnerDateModel)timeSpinner.getModel()).setStart(new Date());
with this code the spinner doesn't work anymore I can't use uo/down buttons to spinn dates nor set values by typing into text field
I dig into this problem and it turn outs that this is probably Swing bug here is code
        Calendar now = Calendar.getInstance();
        Calendar start = Calendar.getInstance();
        start.set(Calendar.HOUR_OF_DAY, now.get(Calendar.HOUR_OF_DAY));
        start.set(Calendar.MINUTE, now.get(Calendar.MINUTE));
        start.set(Calendar.SECOND, now.get(Calendar.SECOND));
        start.set(Calendar.MILLISECOND, now.get(Calendar.MILLISECOND));
        start.add(Calendar.MINUTE, -10);
        Calendar end = Calendar.getInstance();
        end.set(Calendar.HOUR_OF_DAY, now.get(Calendar.HOUR_OF_DAY));
        end.set(Calendar.MINUTE, now.get(Calendar.MINUTE));
        end.set(Calendar.SECOND, now.get(Calendar.SECOND));
        end.set(Calendar.MILLISECOND, now.get(Calendar.MILLISECOND));
        end.add(Calendar.MINUTE, 10);
        JSpinner spinner = new JSpinner(new SpinnerDateModel(now.getTime(),start.getTime(),end.getTime(),Calendar.MINUTE));
        //comment those two lines and it works
        JSpinner.DateEditor de = new JSpinner.DateEditor(spinner, "HH:mm:ss.SSS");
        spinner.setEditor(de);
if in above code I use default DateEditor with default date format it works correctly but if I set DateEditor calling spinner.setEditor(de) I can't change date value anymore
Do you know any workaround for this ?
Thx
Chris
kcieniuch
Re: DateSpinner setStart setEnd swing bug
Postby JIDE Support » Mon Feb 02, 2009 12:23 pm
To be frank, I am not sure. DateSpinner is a simple wrapper around JSpinner. So I am not surprise to hear that this is a Swing bug. I debugged and thought it is a problem in InternationalFormatter#isValidValue method but you may consider posting this to Swing forums or submit the bug to Sun (sorry, we don't provide Swing support).
Postby kcieniuch » Tue Feb 03, 2009 3:05 am
Thanks for info no need to sorry I know you don't provide swing support I just was asking in hope that maybe you came across this problem and already had cleaver workaround :-)
I'll have a look at InternationalFormatter#isValidValue thanks for that tip
thx
Chris
kcieniuch
