JideButton background
Postby andy08 » Sat Jan 31, 2009 1:16 am
I use jide-oss-2.5.0 version.In a simple case,I just add JideButton to the panel.However,the first added JideButton has a default orrange background.Only after other components getfocus,the default orrange background disappear.
So,
1. I want to know why the first added JideButton get focus?
2. Which way is better to customize the JideButton or other JIDE components background? UI delegeate or LookAndFeel?
I just want to use my own painter.
andy08
Re: JideButton background
Postby JIDE Support » Sat Jan 31, 2009 6:56 am
1. Swing automatically put the focus on the first focusable component in the UI. JideButton's focus indicator is to use orange color.
2. There are setBackgroundOfState method you can use to change the background.
Postby andy08 » Sat Jan 31, 2009 7:13 pm
Then how can I make the orange background disappear when the GUI initialize without change the default BackgroundOfState?
I hava try to make a other JComponent getFocus.Say,call JComboBox.requestFocusInWindow.However,it doesn't work :|
I don't like a button has a different bg color at GUI initialize.
Thanks :P
andy08
Postby JIDE Support » Sat Jan 31, 2009 8:13 pm
You need to use SwingUtiltites.invokeLater to requestFocus on other component. Or you can call JideButton#setFocusable(false) and setRequestFocusEnabled(false).
Users browsing this forum: No registered users and 65 guests
