FolderChooser "broken" since version 2.5
Postby maximhallow » Fri Jan 23, 2009 3:11 am
I just downloaded version 2.5 and was surprised because the folderchooser looks very strange: the row height of the JTree ist too big!
What's the reason?
best regard,
Maxim
FolderChooser row height...
maximhallow
Re: FolderChooser "broken" since version 2.5
Postby JIDE Support » Fri Jan 23, 2009 8:05 am
I will fix it asap. Thanks.
Postby maximhallow » Fri Jan 23, 2009 8:15 am
is there a workaround for the moment=?
maximhallow
Postby JIDE Support » Fri Jan 23, 2009 8:49 am
I can't think of any. I already checked in the fix to open source JCL but we still need to make a new build unless you want to grab it from SVN and make a build yourself (but it is not that hard as ant script is there).
Postby maximhallow » Fri Jan 23, 2009 9:17 am
Ok, we will use an older version untill you release a fix. Many thanks.
maximhallow
Postby JIDE Support » Fri Jan 23, 2009 11:13 pm
Please download 2.5.0 release again which fixed this bug.
Users browsing this forum: No registered users and 65 guests
