quick question on JidePopup
Postby siddhaye » Fri Dec 12, 2008 3:35 pm
hi,
I have a question regarding JidePopup.
In my code, I have...
popup.setOwner(MyFrame.getInstance()) ;
popup.DISTANCE_TO_SCREEN_BORDER = 20;
popup.showPopup(currentMouseLocationInScreenCoords.x, currentMouseLocationInScreenCoords.y);
If I understand correctly, shouldn't the code above ensure that if the (x,y) location where popup is shown is too close to the screen border, then the popup will be moved appropriately?
If not, how to achieve that behaviour?
thanks,
Sachin
siddhaye
Re: quick question on JidePopup
Postby JIDE Support » Fri Dec 12, 2008 3:46 pm
You should be able to reuse. Could you create a test case and post it here?
Postby siddhaye » Sun Dec 14, 2008 9:38 am
hi,
actually, I am able to reuse, so I edited my question to something else as you can see posted above, could you please answer that?
thanks,
Sachin
siddhaye
Postby JIDE Support » Sun Dec 14, 2008 10:46 am
No, showPopup(x,y) will show exactly at the x and y position you specified.
