Has JideToggleSplitButton ever worked for anybody?
Postby eiro7Xoo » Wed Dec 03, 2008 3:31 am
Today I tried JideToggleSplitButton (JIDE 1.9.3), and the toggle/untoggle functionality does not work. So I downloaded the most recent stable version 2.4, to see whether it has been fixed already. Apparently not.
Here's the code to reproduce, further down I have a (quick and dirty) fix. Just execute the main method and click the buttons, only one should be active at any time, as they are toggle buttons in a button group. If it looks weird for you, good! You reproduced the bug.
package com.jidesoft.swing;
public class JideToggleSplitButtonTest {
    public static void main(String[] args) throws Exception {
        JPanel panel = new JPanel();
        final ButtonGroup buttonGroup = new ButtonGroup();
        panel.add(t("b1", buttonGroup));
        panel.add(t("b2", buttonGroup));
        panel.add(t("b3", buttonGroup));
        JFrame frame = new JFrame("ToggleTest");
        frame.setDefaultCloseOperation(WindowConstants.EXIT_ON_CLOSE);
        frame.getContentPane().add(panel, BorderLayout.NORTH);
        frame.pack();
    private static AbstractButton t(String s, ButtonGroup bg) {
        JideToggleSplitButton b = new JideToggleSplitButton(s);
        b.setActionCommand(s);
        b.setFocusable(false);
        if (bg != null) bg.add(b);
        b.add(new JMenuItem(s + " menu"));
        return b;
Add the following method to JideToggleSplitButton.ToggleSplitButtonModel and toggling/untoggling will work.
 * Calls from ButtonGroup will be redirected to setButtonSelected(boolean).
 * @param b true selects the menu (or toggle button if called from ButtonGroup), false deselects it
public void setSelected(boolean b) {
    StackTraceElement[] stackFrame = Thread.currentThread().getStackTrace();
    for (int i = 0; i < 5 && i < stackFrame.length; i++) {
        if ("javax.swing.ButtonGroup".equals(stackFrame[i].getClassName())) {
            setButtonSelected(b);
            return;
    super.setSelected(b);
It's ugly, but due to the ambiguity of setSelected (MenuItem vs. Button) I don't know whether there's an easy cleaner fix. Neither did I do extensive tests for side effects and regression. Maybe someone familiar with Jide/Swing internals can share their view on this or propose a better solution.
eiro7Xoo
Re: Has JideToggleSplitButton ever worked for anybody?
Postby JIDE Support » Wed Dec 03, 2008 10:42 am
You need to use SplitButtonGroup instead of ButtonGroup for JideSplitButtons.
Postby eiro7Xoo » Wed Dec 03, 2008 5:40 pm
Now that was easy. Thanks.
Where is this documented? I guess it would make sense to add a little heads-up to the class documentation of JideToggleSplitButton so other people don't have to spend hours of head scratching, googling, checking out the most recent sources, debugging, work-arounding etc. Something like this would have done it for me:
 * An implementation of a two-state JideButton.
 * <p>
 * <strong>Warning:</strong>
 * {@code SplitButtonGroup} has to be used in place of {@code ButtonGroup} for {@code JideToggleSplitButton}s.
eiro7Xoo
Postby JIDE Support » Wed Dec 03, 2008 6:02 pm
The javadoc of SplitButtonGroup mentioned but we should add it to JideSplitButton. I will do that.
Postby eiro7Xoo » Wed Dec 03, 2008 6:19 pm
You mean "we should add it to JideToggleSplitButton", I guess.
eiro7Xoo
Postby JIDE Support » Wed Dec 03, 2008 7:33 pm
That's correct.
Postby JIDE Support » Thu Dec 04, 2008 12:38 pm
Just so you know, the javadoc is added in 2.4.6 which is just released.
Postby eiro7Xoo » Thu Dec 04, 2008 5:04 pm
eiro7Xoo
Users browsing this forum: No registered users and 70 guests
