jide plugin to netbeans
Postby bharath.pati » Tue Dec 02, 2008 11:02 pm
how add jide plugins to netbeans IDE, and how to use JIDE action and docking frame work?
bharath.pati
Re: jide plugin to netbeans
Postby JIDE Support » Tue Dec 02, 2008 11:38 pm
You can view a flash tutorial at http://www.jidesoft.com/demo/tutorial_netbeans.html to find out how to use NB with JIDE. There is no way to use JIDE Docking Framework or JIDE Action Framework using any of the existing GUI builders from other IDEs. You can use Visual Designer (http://www.jidesoft.com/products/1.4/jide_designer.jnlp) or simply code it by hand as most people are doing. There are several examples to show you how to do it in our eval or release package.
