Setting a tooltip for the cells of a SortableTable
Postby fsnolekv » Tue Nov 25, 2008 12:15 pm
Hello All,
I am trying to set tooltip for the cells of a table based on the value of the cell. I see I can override the "getToolTipText" of the SortableTable, but I can't figure out how to get a reference to the cell's value using the MouseEvent. Any suggestions?
Kim
fsnolekv
Re: Setting a tooltip for the cells of a SortableTable
Postby JIDE Support » Tue Nov 25, 2008 12:57 pm
The way tooltip works in JTable is the tooltip can be set on the cell renderer component. JTable will read it from cell renderer component. If you don't have control over the cell renderer component, you can use mouse event to find out the cell (using rowAtPoint and columnAtPoint methods on JTable) and then find out the cell value.
Postby fsnolekv » Tue Nov 25, 2008 1:48 pm
Thanks! RowAtPoint was the special function I needed... :D
fsnolekv
Postby fsnolekv » Tue Nov 25, 2008 2:02 pm
Also, sorry that wasn't Jide related...
fsnolekv
Users browsing this forum: No registered users and 67 guests
