Setting tooltip for headers of a table.
Postby pp_dv » Thu Nov 06, 2008 6:46 am
Hello All,
I am trying to set tooltip for the column headers of a table. While doing so, I am losing the previous font, borders and color values of the table. Though I am able to set back the color but not the font and border.
The code is a bit like this:
public class SampeTable extends TableScrollPane{
private JTable _mainTable=null;
public JTable buildTable(){
if (_mainTable == null)
_mainTable = this.getMainTable();
//Setting the widths as per column specifications
List<TicketColumn> columnsList= _appControlIntf.getBlotterTableModel().getColumns();
Color color=null;
Font font=null;
for(int i=0;i<columnsList.size();i++)
TableColumn tableColumn = null;
switch (getInBlotterTableModel().getColumnType(i))
case MultiTableModel.HEADER_COLUMN:
tableColumn = getRowHeaderTable().getColumnModel().getColumn(i);
break;
default:
tableColumn = getMainTable().getColumnModel().getColumn(i - getRowHeaderTable().getColumnCount());
tableColumn.setPreferredWidth(columnsList.get(i).getWidth());
// Render the first column as a checkbox
if (i == 0)
tableColumn.setCellRenderer(new BooleanCheckBoxCellRenderer());
color = ((BooleanCheckBoxCellRenderer) tableColumn.getCellRenderer()).getBackground();
font = ((BooleanCheckBoxCellRenderer) tableColumn.getCellRenderer()).getFont();
font = font.deriveFont(Font.BOLD);
tableColumn.setCellEditor(new BooleanCheckBoxCellEditor());
else
JLabel headerRenderer = new DefaultTableCellRenderer();
headerRenderer.setBackground(color);
headerRenderer.setFont(font);
headerRenderer.setToolTipText("Hello");
tableColumn.setHeaderRenderer((TableCellRenderer) headerRenderer);
initializeTable(_mainTable);
initializeTable(getRowHeaderTable());
return _mainTable;
private void initializeTable(JTable table)
table.setAutoResizeMode(JTable.AUTO_RESIZE_OFF);
table.setSelectionMode(ListSelectionModel.MULTIPLE_INTERVAL_SELECTION);
((SortableTable) table).setOptimized(true);
JTableHeader header = table.getTableHeader();
header.setBorder(BorderFactory.createRaisedBevelBorder());
header.setFont(header.getFont().deriveFont(java.awt.Font.BOLD));
table.addMouseListener(new MouseListener()
public void mouseReleased(MouseEvent e)
showPopup(e);
public void mousePressed(MouseEvent e)
showPopup(e);
private void showPopup(MouseEvent e)
if (e.isPopupTrigger())
getInboundBlotterPopup().show(e.getComponent(), e.getX(), e.getY());
public void mouseClicked(MouseEvent e)
if (e.getClickCount() == 2)
_appControlIntf.showFixMessageBlotter(getSelectedInboundTicketView());
public void mouseEntered(MouseEvent e)
public void mouseExited(MouseEvent e)
With the above code, I am able to set the tooltip text, but the font and border are being compromised. For the column (i=0), the font and borders are fine as I am not using the DefaultCellRenderer. For the rest of the columns the color attribute is being set but not the font. I even tried to set the borders using the setBorder(), but to no avail.
Any help would be appreciated. Let me know if more inputs/code is required.
pp_dv
pp_dv
Re: Setting tooltip for headers of a table.
Postby JIDE Support » Thu Nov 06, 2008 8:12 am
You don't want to use your own cell renderer for table header as you will never get the same border and style for some L&Fs. Please use an interface called ToolTipSupport we introduced. There is a sample in SortableTableDemo to show you how to use it.
Postby pp_dv » Fri Nov 07, 2008 9:10 am
Thanks for the reply.
My situation is a bit like this: The _mainTable has a SortableTableModel which recursively nests to a custom table model class. I have made my custom table model class implement ToolTipSupport with necessary implementation. But still when I run my applet, I don't see the tool tip. I have debugged the _mainTable attribute and found that the dataModel attribute was deeply nested to the custom table model class.
I am not sure if I am missing something here.
public class InBlotterTableModel extends DVAbstractBlotterTableModel implements Runnable, LogIDProvider, ToolTipSupport{
///Some code here
public String getToolTipText(int columnIndex)
return InboundTicketViewColumns.COLUMNS.get(columnIndex).getName();
I also tried to add a breakpoint in the InBlotterTableModel at the implemented method. But the break point was never reached.
pp_dv.
pp_dv
Postby JIDE Support » Fri Nov 07, 2008 9:54 am
We actually find the nested table model that implements ToolTipSupport and use it. Could you please make a simple test case for it and post here?
Postby Walter Laan » Mon Nov 10, 2008 1:44 am
Reading this thread I tought lets add header tooltips to our program, but I got the same problem.
It happens when a new table header is set or createDefaultTableHeader() is overridden.
Add the following code to SortableTableDemo:
_sortableTable = new SortableTable(new SortableTableModel(tableModel)) {
  protected JTableHeader createDefaultTableHeader() {
    return new SortableTableHeader(getColumnModel());
// or only the to following line also shows the problem
// _sortableTable.setTableHeader(new SortableTableHeader(_sortableTable.getColumnModel()));
So if you could add a protected method installTableHeaderTooltips(), we could call that when overriding the createDefaultTableHeader method and you can call it in setTableHeader().
Walter Laan
Postby pp_dv » Mon Nov 10, 2008 6:36 am
Thanks for all your replies. I have found a workaround for this issue. I had added a mouse listener and mouse motion listener to the table header. These listeners do the job of displaying the tooltip. It seems to be working fine.
Thanks again.
pp_dv
pp_dv
Postby JIDE Support » Mon Nov 10, 2008 11:36 am
The table header has to know how to retrieve the tooltip. Here is our code in JideTable.
        if (isNestedTableHeader()) {
            return new NestedSortableTableHeader(getColumnModel()) {
                public String getToolTipText(MouseEvent event) {
                    String toolTipText = getTableHeaderToolTipText(event);
                    if (toolTipText != null) {
                        return toolTipText;
                    else {
                        return super.getToolTipText(event);
        else {
            return new SortableTableHeader(getColumnModel()) {
                        return toolTipText;
                    else {
