by jmapdev » Thu Oct 30, 2008 8:05 am
We are looking to use JIDE Components in our application. We currently have a "toogle split button" that is updated with the menu item. Also, this button is part of a button group ... Is it possible to do that with JIDE Components?
Here is an example :
- Our split button
- Picture 1.png (3.17 KiB) Viewed 11428 times
- Button with the popup menu
- Picture 2.png (12.96 KiB) Viewed 11429 times
- The "Circular selection" option is selected
- Picture 3.png (3.53 KiB) Viewed 11429 times
Sébastien
jmapdev
by JIDE Support » Thu Oct 30, 2008 9:40 am
JideSplitButton can do that. SplitButtonGroup is the replacement for ButtonGroup except it works with JideSplitButton.
Users browsing this forum: No registered users and 81 guests
