DateSpinner
DateSpinner
Postby dcf » Thu Sep 25, 2008 5:01 am
Hello.
I am using a DateSpinner object in my swing app. It displays the current date fine, but when the component is changed, the getValue() method only returns the original date - it does not capture the date entered by the user.
I have also tried using the commitEdit() prior to the getValue() method. Any ideas as to what I'm doing wrong?
dcf
Re: DateSpinner
Postby JIDE Support » Thu Sep 25, 2008 6:41 am
Do you mean the new date value user typed? Did you try press ENTER? I remembered JSpinner requires an extra enter to commit the value.
Re: DateSpinner
Postby dcf » Thu Sep 25, 2008 7:09 am
Yes, I mean after the user types in the change. It does not work after hitting enter - and it does not seem as though it should be necessary from a user's perspective.
dcf
Re: DateSpinner
Postby JIDE Support » Thu Sep 25, 2008 7:22 am
Unfortunately that's how Swing JSpinner works. DateSpinner simply extends JSpinner. I don't yet know how to change it. I would think commitEdit should work but you said you tried it already.
Users browsing this forum: No registered users and 67 guests
