Background color for a JideButton?
Postby jeremy_c » Mon Sep 08, 2008 8:20 pm
Is it possible to set the background color of a JideButton? I have tried setBackground w/no luck.
Jeremy
jeremy_c
Re: Background color for a JideButton?
Postby JIDE Support » Mon Sep 08, 2008 8:30 pm
You can use setBackgroundOfState to set for different states. The setBackground will work too for the normal state only if you call setContentAreaFilled(true).
Postby jeremy_c » Mon Sep 08, 2008 9:06 pm
I've tried:
                    b.setBackground(new Color(255, 200, 200));
                    b.setBackgroundOfState(1, new Color(200, 200, 255));
                    b.setBackgroundOfState(0, new Color(200, 200, 255));
                    b.setBackgroundOfState(2, new Color(200, 200, 255));
                    b.setContentAreaFilled(true);
w/no luck. What would be a valid value for state? I cannot determine that from the API docs. Thank you very much!
Jeremy
jeremy_c
Postby JIDE Support » Mon Sep 08, 2008 9:18 pm
I'll add javadoc for it. The states are defined in ThemePainter. ThemePainter.STATE_DEFAULT, STATE_ROLLOVER, STATE_SELECTED and STATE_PRESSED.
Sorry, setContentAreaFilled should be setOpaque.
Postby jeremy_c » Mon Sep 08, 2008 9:50 pm
Ah! Got it. Thanks. It is in the java docs, I missed it. When you pointed me to ThemePainter, I found it pretty easily. Now looking back, I notice that JideButton implements ComponentStateSupport which will get me to ThemePainter, but it was not obvious at start. Sorry, should have read more.
Everything is working great now, thanks for the quick response!
Jeremy
jeremy_c
Postby JIDE Support » Tue Sep 30, 2008 9:27 am
Just so you know, 2.4.0 is released which adds more javadoc for the methods you have trouble with.
Users browsing this forum: No registered users and 71 guests
