AutoCompletionComboBox and JTables
Postby stacecase » Sat Sep 06, 2008 1:18 pm
I am creating a program where I want to type in a lot of information really quickly in a JTable. I want to use the AutoCompletionComboBox inside the table, but when you tab to the field and start typing, you have to click the mouse inside the field to get it to start working. Is there a way to get it to let you tab inside and start typing?
Here is the TableRenderDemo.java from the java tutorials where I added an autocompletioncomboBox to illustrate the problem. It would be nice to tab to the sports column and start typing without clicking with the mouse.
import com.jidesoft.swing.AutoCompletionComboBox;
import javax.swing.DefaultCellEditor;
import javax.swing.JTable;
import javax.swing.table.AbstractTableModel;
import javax.swing.table.DefaultTableCellRenderer;
import javax.swing.table.TableColumn;
import java.awt.Dimension;
import java.awt.GridLayout;
 * TableRenderDemo is just like TableDemo, except that it
 * explicitly initializes column sizes and it uses a combo box
 * as an editor for the Sport column.
public class TableRenderDemo extends JPanel {
    private boolean DEBUG = false;
    public TableRenderDemo() {
        super(new GridLayout(1,0));
        JTable table = new JTable(new MyTableModel());
        table.setPreferredScrollableViewportSize(new Dimension(500, 70));
        table.setFillsViewportHeight(true);
        JScrollPane scrollPane = new JScrollPane(table);
        setUpSportColumn(table, table.getColumnModel().getColumn(2));
        add(scrollPane);
    public void setUpSportColumn(JTable table,
                                 TableColumn sportColumn) {
        AutoCompletionComboBox comboBox = new AutoCompletionComboBox();
        comboBox.setStrict(false);
        comboBox.addItem("Snowboarding");
        comboBox.addItem("Rowing");
        comboBox.addItem("Knitting");
        comboBox.addItem("Speed reading");
        comboBox.addItem("Pool");
        comboBox.addItem("None of the above");
        sportColumn.setCellEditor(new DefaultCellEditor(comboBox));
        DefaultTableCellRenderer renderer =
                new DefaultTableCellRenderer();
        renderer.setToolTipText("Click for combo box");
        sportColumn.setCellRenderer(renderer);
    class MyTableModel extends AbstractTableModel {
        private String[] columnNames = {"First Name",
                                        "Last Name",
                                        "Sport",
                                        "# of Years",
                                        "Vegetarian"};
        private Object[][] data = {
            {"Mary", "Campione",
             "Snowboarding", new Integer(5), new Boolean(false)},
            {"Alison", "Huml",
             "Rowing", new Integer(3), new Boolean(true)},
            {"Kathy", "Walrath",
             "Knitting", new Integer(2), new Boolean(false)},
            {"Sharon", "Zakhour",
             "Speed reading", new Integer(20), new Boolean(true)},
            {"Philip", "Milne",
             "Pool", new Integer(10), new Boolean(false)}
        public final Object[] longValues = {"Sharon", "Campione",
                                            "None of the above",
                                            new Integer(20), Boolean.TRUE};
        public int getColumnCount() {
            return columnNames.length;
        public int getRowCount() {
            return data.length;
        public String getColumnName(int col) {
            return columnNames[col];
        public Object getValueAt(int row, int col) {
            return data[row][col];
        public Class getColumnClass(int c) {
            return getValueAt(0, c).getClass();
        public boolean isCellEditable(int row, int col) {
            if (col < 2) {
                return true;
        public void setValueAt(Object value, int row, int col) {
            data[row][col] = value;
            fireTableCellUpdated(row, col);
        private void printDebugData() {
            int numRows = getRowCount();
            int numCols = getColumnCount();
            for (int i=0; i < numRows; i++) {
                for (int j=0; j < numCols; j++) {
    private static void createAndShowGUI() {
        JFrame frame = new JFrame("TableRenderDemo");
        TableRenderDemo newContentPane = new TableRenderDemo();
        newContentPane.setOpaque(true); //content panes must be opaque
        frame.setContentPane(newContentPane);
        frame.pack();
        javax.swing.SwingUtilities.invokeLater(new Runnable() {
            public void run() {
                createAndShowGUI();
stacecase
Re: AutoCompletionComboBox and JTables
Postby JIDE Support » Sat Sep 06, 2008 9:47 pm
That's how JTable behaviors and it has nothing to do with auto-completion as the cell is not even in edit mode yet. Auto-completion is only used when cell starts editing. You can use F2 to start editing instead of using mouse. JIDE Grids's JideTable does have an option (JideTable#setAutoStartCellEditing(true)) to start editing when TAB is pressed. But it is not in JCL.
Users browsing this forum: No registered users and 66 guests
