CheckBoxTree: coordinates of checkboxes
Postby DDJ4 » Mon Aug 25, 2008 6:52 am
I'm writing sort of an automation tool that uses Jemmy to drive GUI components one of which is going to be CheckBoxTree. The objection is to be able to perform mouse click on CheckBoxTree nodes' check boxes. For this I will need to find a way of determining checkboxes coordinates.
Question: is there a way to determinate coordinates of a specific checkbox? Could anybody suggest a solution?
Thank you.
DDJ4
Re: CheckBoxTree: coordinates of checkboxes
Postby JIDE Support » Mon Aug 25, 2008 9:23 am
We don't provide any public API for it. You can use JTree.getPathForLocation to find out the the tree path. If the CheckBoxTree#isCheckBoxVisible(path) is true, you can then check the x to make sure it is within a regular empty JCheckBox's preferred width to determine it is within the check box.
