Displaying checkbox in sortable table
Postby mgonjedif » Mon Jul 28, 2008 3:13 am
Hi, I am having problem in displaying checkbox in sortable table. When rendered in a SortableTable, column is rendered as text..
Looking at JIDE demo, SortableTableDemo, I would like to display checkbox in 3rd column when displayed in SortableTableModel, similar to, in case of Normal TableModel.
mgonjedif
Postby JIDE Support » Mon Jul 28, 2008 9:10 am
We used ComboBox as the boolean cell editor by default as it looks more consistent in the table as most cells are strings. If you prefer to use check box, you just need to implement getEditorContextAt method on ContextSensitiveTableModel.
        public EditorContext getEditorContextAt(int row, int column) {
            return BooleanCheckBoxCellEditor.CONTEXT for the column that is boolean. Otherwise return null.
Users browsing this forum: No registered users and 75 guests
