Removing row from SortableTable
Postby govindaxp » Wed Jul 23, 2008 9:01 pm
Is it possible to remove row from sortable table if yes then how??
govindaxp
Postby JIDE Support » Wed Jul 23, 2008 9:22 pm
Removing row actually has nothing to do with SortableTable. You just remove it from your original table model and fireTableRowDeleted event. If your original table model is DefaultTableModel, there is removeRow method. If you are using AbstractTableModel, then you need to implement your own remove row logic. Whatever it is, the row will be removed automatically from SortableTable if you remove it from the original table model.
Postby govindaxp » Wed Jul 23, 2008 9:32 pm
thanks i was not firing the event .
govindaxp
