How to remove toggle autohide button
Postby govindaxp » Wed Jul 16, 2008 9:39 pm
How can i remove the toggle auto hide and hide active auto hide window button from my frame??
I am trying to modify docking framework demo , but not able to remove it from West frame, although its not appearing on East Frame.
I am using this code to remove :
frame.setAutohidable(false);
frame.setFloatable(false);
frame.setDockable(false);
frame.setHidable(false);
govindaxp
Postby JIDE Support » Wed Jul 16, 2008 10:04 pm
If you are on Windows, can you try to delete the previous saved layout from the registry at HKEY_CURRENT_USER\Software\JavaSoft\Prefs then run your application again? The settings are part of the layout so I wonder if they were saved as true before.
Postby govindaxp » Wed Jul 16, 2008 10:09 pm
Thanx a Lot
govindaxp
Postby govindaxp » Mon Jul 21, 2008 8:43 pm
can u please explain the reason behind that??
govindaxp
Postby JIDE Support » Mon Jul 21, 2008 9:27 pm
Sure. Those -able flags are part of the layout. So unless you set them after the layout is loaded, otherwise it will use whatever in the layout.
Users browsing this forum: No registered users and 76 guests
