DockableFrame, "not always on top"
Postby AVXT » Mon Jul 07, 2008 2:20 am
I use DockableFrame. When I undock the frame, I want it to be "not always on top". Is there a way to do this?
AVXT
Postby JIDE Support » Mon Jul 07, 2008 9:06 am
You can try to run with system property -Ddocking.floatingContainerType=frame. The property will use JFrame as the floating container. JFrame will hide/show independently from the main JFrame. The floating frame can go behind the main frame. In order to bring it back, there is a task bar entry for it.
Postby AVXT » Wed Jul 16, 2008 8:00 am
Thanks, but this don't work.
I find some methods:
isSlidingAutohide
public boolean isSlidingAutohide()
This is a flag to determine the displaying behavior of a dockable frame when it is in autohidden mode. If this flag is true, autohide window will slide out on top of other contents in the main container. If false, autohide window will push the contents in the main container aside so no contents will be covered.
Returns:
true or false.
and
setSlidingAutohide
public void setSlidingAutohide(boolean slidingAutohide)
Sets the displaying behavior of a dockable frame when it is in autohidden mode.
Please set the flag during initialization of the dockable frame. We don't support changing this flag on fly.
Parameters:
slidingAutohide - true or false.
See Also:
isSlidingAutohide()
But this don't work too(
DockableFrame always on top (by default) on docking and on floating.
AVXT
Postby JIDE Support » Wed Jul 16, 2008 8:09 am
I am pretty sure both should work. Can you reproduce it in DockingFrameDemo? If yes, let me know how.
