Setting Selections on CheckBoxTree
Postby djskiffington » Wed Jun 25, 2008 7:52 am
I've got a CheckBoxTree that is working and I am able to get the user selections without any problem. However, I have a situation where I need to set specific leaf nodes to selected after the tree has been constructed and I don't see an easy way to accomplish this. I tried to loop through the rows and get the path for each row, but that doesn't work for rows that are not currently visible. Any other suggestions on how to do this?
djskiffington
Postby JIDE Support » Wed Jun 25, 2008 8:40 am
You have use get the TreePath and then use as getCheckBoxTreeSelectionModel to select it. Of course you can't use getPathForRow kind of methods if it is not visible. But it is still possible to construct a TreePath for it if you know exactly which node you are trying to select, even the node is not visible.
Postby djskiffington » Wed Jun 25, 2008 11:50 am
Do you have any examples of how this should work ?
I tried using new TreePath(treeModel.getPathToRoot(child)) to reconstruct the path to the node. I then pass this TreePath to the CheckBoxTree setSelectionPath, but my checkbox is never selected. I also tried reconstructing the path by using new TreePath(Object[]) where my object list is the list of nodes from root to child, but that didn't work either.
djskiffington
Postby JIDE Support » Wed Jun 25, 2008 11:57 am
Not CheckBoxTree's setSelectionPath. That's for the blue highlight kind of selection, not for check boxes. As I mentioned in my previous post, you need to use getCheckBoxTreeSelectionModel to get the selection model for the checkboxes.
Postby djskiffington » Wed Jun 25, 2008 12:36 pm
Thanks. That corrected my problem.
djskiffington
