JideTabbedPane setTabComponentAt
Postby akarl16 » Fri Jun 13, 2008 12:07 pm
I am attempting to set a custom component which I would like to act as my tab header for each tab. I am just using a simple label. It seems that JideTabbedPane overrides that value somehow because my labels are not showing. If I switch my tabbed pane back to a JTabbedPane they do work so I believe I am using that method correctly. Is there some trick I can use to make this work using JideTabbedPane?
JideTabbedPane pane = ......
JLabel label = .....
pane.setTabComponentAt(0, label);
akarl16
Postby JIDE Support » Fri Jun 13, 2008 12:10 pm
The setTabComponentAt method doesn't work with JideTabbedPane. We based JideTabbedPane code on JDK5's code. And the setTabComponentAt is added in JDK6.
There is something we will do in the future but no immediate plan yet. Feel free if you decide to help us on this as JideTabbedPane is open source project and love you guys contribution.
Postby kristin » Fri Aug 01, 2008 9:05 am
Has this been fixed yet? If not, are there any plans to do this in the near future?
kristin
Postby JIDE Support » Fri Aug 01, 2008 9:27 am
It will probably take a while before we work on it.
Users browsing this forum: Bing [Bot] and 5 guests
