by eye1 » Thu Jun 12, 2008 4:21 am
Is it possible to add and/or remove items in CheckBoxList after it is constructed.
like:
checkBoxList.addItem("FIRST");
checkBoxList.removeItem("FIRST");
eye1
by eye1 » Thu Jun 12, 2008 6:15 am
Ok I solved this
init:
- Code: Select all
CheckBoxList cblTags = new CheckBoxList();
DefaultListModel model = new DefaultListModel();
cblTags.setModel(model);
runtime:
- Code: Select all
DefaultListModel model = (DefaultListModel)cblTags.getModel();
model.addElement("ITEM 1");
eye1
