child tables go away when MultilineTableCellRenderer used
Postby ack1035 » Tue Jun 10, 2008 10:10 am
When I override getCellRenderer() on my hierarchical table class, and have it return a MultilineTableCellRenderer, the rows no longer expand to show the child tables. In fact the hasChild() method on my TableModel isn’t even called.
Is it possible to have rows that both expand into child tables and use a MultilineTableCellRenderer?
Alex
ack1035
Postby JIDE Support » Tue Jun 10, 2008 10:13 am
If possible, can you try to modify HierarchicalTableDemo to reproduce the issue and email or post here the changed code?
Postby ack1035 » Tue Jun 10, 2008 12:05 pm
I emailed the modified code, which reproduced the following results:
-word wrap is now enabled, but
-items in the subtables that formerly had children no longer do ("ComboBox" and "CellEditors")
Here's an excerpt to show how I did this (around line 139):
TableModel model = ((TableModel) value);
if (model instanceof HierarchicalTableModel) {
HierarchicalTable childTable = new HierarchicalTable(model) {
public void scrollRectToVisible(Rectangle aRect) {
HierarchicalTableDemo.scrollRectToVisible(this, aRect);
TableCellRenderer cellRenderer =
new MultilineTableCellRenderer();
public TableCellRenderer getCellRenderer(int row, int column) {
return cellRenderer;
childTable.setRowAutoResizes(true);
The behavior I'd like is to have both the word wrap and not to lose subtables.
Alex
ack1035
Postby JIDE Support » Tue Jun 10, 2008 12:43 pm
I see. Of course you won't see the +/- icon as you override our cell renderer that paints the +/- icon. The correct way is to use our CellRenderer/EditorManager way. Just get rid of your code of getCellRenderer and use the code below for the model.
    static class GridsProductTableModel extends DefaultContextSensitiveTableModel implements HierarchicalTableModel {
        public GridsProductTableModel() {
            super(JIDE_GRIDS, DETAIL_COLUMNS);
        public Class<?> getCellClassAt(int row, int column) {
            return String.class;
        public EditorContext getEditorContextAt(int row, int column) {
            return MultilineTableCellRenderer.CONTEXT;
        public boolean isCellEditable(int row, int column) {
        public boolean hasChild(int row) {
            Object name = getValueAt(row, 0);
            if ("CellEditors".equals(name) || "ComboBox".equals(name)) {
                return true;
            else {
        public boolean isHierarchical(int row) {
            return true;
        public boolean isExpandable(int row) {
            return true;
        public Object getChildValueAt(int row) {
            TableModel model = null;
            if ("ComboBox".equals(name)) {
                model = new DefaultTableModel(JIDE_COMBOBOXES, DETAIL_COLUMNS) {
            else if ("CellEditors".equals(name)) {
                model = new DefaultTableModel(JIDE_CELLEDITORS, DETAIL_COLUMNS) {
            return model;
