Newbie to JIDE (CheckBoxTree)
Postby dinaharchery » Wed Apr 23, 2008 8:02 am
Hello all,
I am a newbie to the JIDE API and have a few questions that I hope someone can help me with.
I have tried using the JIDE CheckBoxTree Class but the javadoc API does not seem to provide much info on exactly how this Class works. Is there a tutorial for the use of JIDE (in particular the CheckBoxTree Class)?
I am trying to allow the user to click a parent TreeNode and select all children in the sub-tree or just expand/collapse a sub-tree or select each tree node individually. Is this possible and if so, how? Maybe some simple code sample :D .
Thanks for any help/hints.
dinaharchery
Postby Guest » Wed Apr 23, 2008 8:23 am
First, thank you for your interest in JIDE.
In the first instance, please visit http://www.jidesoft.com/products/download.htm and download the JIDE_Common_Layer_Developer_Guide.doc. This document explains how to use the CheckBoxTree class.
Also on this page, is a Java Web Start demo. In this demo you'll find the source code to the example in question.
I hope this helps.
Guest
Postby dinaharchery » Thu Apr 24, 2008 5:48 am
Thank you Marek2008.
The information you gave me was very helpful.
dinaharchery
Postby Guest » Thu Apr 24, 2008 6:12 am
Your welcome :D
Guest
Users browsing this forum: No registered users and 74 guests
