MultiplePageDialog pack()
Postby jtheuer » Fri Apr 11, 2008 2:35 am
Hi, I created a MPD. But its initial size is very small. Furthermore, the buttons stick at the bottom-right border, I expected a cleaner look when I read the pdf tutorial. Did I do something wrong?
Copyright 2007 52North Initiative for Geospatial Open Source Software GmbH
package de.jtheuer.diki.gui;
import java.awt.Component;
 * @author Jan Torben Heuer <jan.heuer@uni-muenster.de>
 * Configuration window for diki
public class ConfigurationWindow extends MultiplePageDialog implements DikiStrings {
   /* automatically generated Logger */@SuppressWarnings("unused")
   private static final Logger LOGGER = Logger.getLogger(ConfigurationWindow.class.getName());
   private Properties properties;
   private final Component rootFrame;
   public ConfigurationWindow(Frame owner, Properties properties) {
      super(owner,Messages.getString("ConfigurationWindow.1"),true,ICON_STYLE); //$NON-NLS-1$
      rootFrame = owner;
      this.properties = properties;
      setTitle(Messages.getString("ConfigurationWindow.1"));
      setPageList(getPages());
      pack();
      setVisible(true);
   private PageList getPages() {
      PageList pages = new PageList();
      pages.addElement( new AbstractDialogPage("general",ResourcesContainer.CONFIGURE.getAsIcon(32)) {
         /** The general dialog */
         private static final long serialVersionUID = 0L;
         public void lazyInitialize() {
            add(new JTextField());
      pages.addElement( new AbstractDialogPage("moduels",ResourcesContainer.MODULES.getAsIcon(32)) {
         /** The modules dialog */
      pages.addElement( new AbstractDialogPage("Themes",ResourcesContainer.MODULES.getAsIcon(32)) {
            JComboBox combobox = new JComboBox(UIController.getAvailableLnFs());
            combobox.addItemListener(UIController.getListener(combobox,rootFrame,this));
            add(combobox);
      return pages;
Jan
jtheuer
Postby JIDE Support » Fri Apr 11, 2008 6:54 am
All our dialog pages are lazily loaded. You don't want to load them when the dialog is created as it could take a long time to create all the pages in the MPD. So the way you pack() in the constructor will stop this lazy loading from working. The correct way is to do it outside. Just take a look at our demo and try to use the same pattern as we are using in the demo.
Users browsing this forum: No registered users and 75 guests
