JideTabbedPane Border
Postby robert » Thu Apr 03, 2008 7:36 am
I'm evaluating Jide for possible inclusion in my project. The first component I'm trying out is the JideTabbedPane. I'm wondering if there is a way to remove the border around the pane? If not, could this be added in a future release?
I'm currently using JGoodies Looks. With Looks I can remove the border with this:
tabPane.putClientProperty(Options.NO_CONTENT_BORDER_KEY, Boolean.TRUE)
However, when I change the JTabbedPane to a JideTabbedPane, a border is added back. I find that the border is an unnecessary visual distraction, especially when using Windows LAF, where the border is a bright orange colour. Is there any way to remove this?
Also, setBoldActiveTab(true) does not seem to work when using Metal LAF.
robert
Postby JIDE Support » Thu Apr 03, 2008 8:05 am
Actually the orange color matches with the tab selection color which is used to indcate the tabbed pane has focus.
An easy way to get rid of is to use JideTabbedPane#setContentBorderInsets(new Insets(0,0,0,0)).
Postby robert » Thu Apr 03, 2008 11:25 am
Thanks for the solution. I ended up setting the Insets to (1,0,0,0). This retains a small top border, similar to the JGoodies Looks.
robert
Users browsing this forum: No registered users and 76 guests
