one touch expandable jidesplitpane
Postby lievendoclo » Tue Apr 01, 2008 1:55 am
Are there plans on adding the one-touch expandable functionality as seen in the standard JSplitPane into JideSplitPane? It's one of the things which denies the use of JideSplitPane in our applications.
lievendoclo
Postby JIDE Support » Tue Apr 01, 2008 7:16 am
We thought about it but there is no immediate plan to do it. The purpose of JideSplitPane is not to replace JSplitPane in all cases but only when multiple split is needed. Having one touch buttons for multiple split in kind of tricky. Should it expand all the way or just one pane at a time?
Postby JIDE Support » Tue Jun 03, 2008 2:51 pm
We introduced this onetouch expandable feature to JideSplitPane in 2.2.7 release. You can check it out in JideSplitPaneDemo.
