JideTabbedPane titles with left tab placement
Postby jhoffman » Tue Mar 04, 2008 11:43 am
JideTabbedPane handles left/right tab placement nicely, turning the title text sideways like it does. Unfortunately, it doesn't seem to care if the tabs are on the left or right side, it always turns the text the same way.
Is there any chance of adding the option of which way to rotate the text? This is already present in VerticalLabelUI.
Thanks!
jhoffman
Postby JIDE Support » Tue Mar 04, 2008 3:27 pm
I checked in BasicJideTabbedPaneUI which does the rotate for LEFT tab placement. You can check out the source code from JIDE Common Layer. I was puzzled by a place where I have to +7 when calcuating. If you could help me figuring out what's going on, I appreciate.
g2d.translate(-textRect.height + 7, 0); // no idea why i need 7 here
Postby JIDE Support » Thu Mar 06, 2008 4:54 pm
Just so you know, this is fixed in 2.2.2.01 release.
