Problems with Layout
Postby dhanush » Wed Jan 23, 2008 6:37 am
1. My project holding some DockableFrames and saving the layout in .txt file and loading it from there when Im logging to my project next time. If I create
all DockableFrames before loading the layout I can see the same layout what i saved. If I create dockableFrames after loading the layout it will not work.
2. After loading the layout and then when we add a dockable frame to holder panel , all old dockable frames goes to the original position and not to the position stored in layout raw data.
Is there any solution for solving these problems?
dhanush
Postby JIDE Support » Wed Jan 23, 2008 8:12 am
What code do you use when you create a new dockable frame and add it? All you should do is new DockableFrame and then DockingManager#addFrame(frame). This shouldn't cause the layout to reset.
Users browsing this forum: No registered users and 76 guests
