JideSplitPane - equivalent to setResizeWeight()?
Postby martin.guetlein » Mon Dec 17, 2007 4:00 am
I have the following problem with JideSplitPane:
I have 2 Components, left and right. The left component should be as big as its preferred size, and the right component should get all the extra space.
This is done in a JSplitPane by default (and can be controlled via setResizeWeight() ).
What JideSplitPane does is setting the divider somewhere in between, i.e. the left component is getting too much space.
Neither setProportions() (as I dont know the total size of the split pane) nor setDividerLocation() work properly (does only work after the split-pane is painted at least once).
Thanx for help,
Martin
martin.guetlein
Postby JIDE Support » Mon Dec 17, 2007 8:28 am
JideSplitPane supports it too. You just add the second component using JideBoxLayout.VARY contraint. Refer to JideBoxLayout for more details as JideSplitPane uses it.
Users browsing this forum: Bing [Bot] and 81 guests
