LabeledPasswordField ?
Postby albedo » Wed Dec 12, 2007 7:48 am
 * @(#)ShortcutField.java 7/9/2002
 * Copyright 2002 - 2002 JIDE Software Inc. All rights reserved.
package com.jidesoft.swing;
import com.jidesoft.plaf.UIDefaultsLookup;
import com.jidesoft.utils.SystemInfo;
import java.awt.event.MouseAdapter;
import java.awt.event.MouseEvent;
import java.lang.reflect.InvocationTargetException;
import java.lang.reflect.Method;
 * <code>LabeledPasswordField</code> is a combo component which includes text field and
 * an optional JLabel in the front and another optionial AbstractButton at the end.
public class LabeledPasswordField extends JPanel {
    protected JPasswordField _textField;
    protected JLabel _label;
    protected AbstractButton _button;
    protected String _labelText;
    protected Icon _icon;
    public LabeledPasswordField() {
        this(null, null);
    public LabeledPasswordField(Icon icon) {
        this(icon, null);
    public LabeledPasswordField(Icon icon, String labelText) {
        super();
        _icon = icon;
        _labelText = labelText;
        initComponent();
    protected void initComponent() {
        _label = createLabel();
        if (_label != null) {
            _label.addMouseListener(new MouseAdapter() {
                public void mouseClicked(MouseEvent e) {
                public void mousePressed(MouseEvent e) {
                    showMenu();
                public void mouseReleased(MouseEvent e) {
                protected void showMenu() {
                    if (isEnabled()) {
                        JidePopupMenu menu = createContextMenu();
                        if (menu != null && menu.getComponentCount() > 0) {
                            Point location = _label.getLocation();
                            menu.show(LabeledPasswordField.this, location.x + (_label.getIcon() == null ? 1 : _label.getIcon().getIconWidth() / 2), location.y + _label.getHeight() + 1);
        _button = createButton();
        _textField = createTextField();
        initLayout(_label, _textField, _button);
        updateUI();
     * Setup the layout of the components. By default, we used a border layout
     * with label first, field in the center and button last.
     * @param label  the label
     * @param field  the text field.
     * @param button the button
    protected void initLayout(JLabel label, JTextField field, AbstractButton button) {
        setLayout(new BorderLayout(3, 3));
        if (label != null) {
            add(label, BorderLayout.BEFORE_LINE_BEGINS);
        add(field);
        if (button != null) {
            add(button, BorderLayout.AFTER_LINE_ENDS);
     * Creates a text field. By default it will return a JTextField with opaque set to false. Subclass
     * can override this method to create their own text field such as JFormattedTextField.
     * @return a text field.
    protected JPasswordField createTextField() {
        JPasswordField textField = new JPasswordField();
        SelectAllUtils.install(textField);
        textField.setOpaque(false);
        textField.setColumns(20);
        return textField;
     * Creates a context menu. The context menu will be shown when user clicks on the label.
     * @return a context menu.
    protected JidePopupMenu createContextMenu() {
        return null;
    public void updateUI() {
        super.updateUI();
        setBorder(BorderFactory.createCompoundBorder(UIDefaultsLookup.getBorder("TextField.border"), BorderFactory.createEmptyBorder(2, 2, 2, 2)));
        if (isEnabled()) {
            LookAndFeel.installColors(this, "TextField.background", "TextField.foreground");
        else {
            LookAndFeel.installColors(this, "TextField.inactiveBackground", "TextField.foreground");
        if (_textField != null) {
            _textField.setBorder(BorderFactory.createEmptyBorder());
     * Creates the button that appears after the text field. By default it returns null so there is no button. Subclass can
     * override it to create their own button. A typical usage of this is to create a browse button to browse a file or directory.
     * @return the button.
    protected AbstractButton createButton() {
        return null;
     * Creates the label that appears before the text field. By default, it only has a search icon.
     * @return the label.
    protected JLabel createLabel() {
        JLabel label = new JLabel(_icon);
        label.setText(_labelText);
        return label;
     * Sets the text that appears before the text field.
     * @param text the text that appears before the text field.
    public void setLabelText(String text) {
        _labelText = text;
            _label.setText(text);
     * Gets the text that appears before the text field.
     * @return the text that appears before the text field. By default it's null, meaning no text.
    public String getLabelText() {
            return _label.getText();
        else {
            return _labelText;
     * Sets the icon that appears before the text field.
     * @param icon the icon that appears before the text field.
    public void setIcon(Icon icon) {
        _icon = icon;
            _label.setIcon(icon);
     * Gets the icon that appears before the text field.
     * @return the icon that appears before the text field.
    public Icon getIcon() {
            return _label.getIcon();
        else {
            return _icon;
     * Gets the JLabel that appears before text field.
     * @return the JLabel that appears before text field.
    public JLabel getLabel() {
        return _label;
     * Gets the AbstractButton that appears after text field.
     * @return the AbstractButton that appears after text field.
    public AbstractButton getButton() {
        return _button;
     * Sets the number of columns in this TextField, and then invalidate the layout.
     * @param columns the number of columns for this text field.
    public void setColumns(int columns) {
        if (getTextField() != null) {
            getTextField().setColumns(columns);
     * Gets the actual text field.
     * @return the actual text field.
    public JTextField getTextField() {
        return _textField;
    public void setEnabled(boolean enabled) {
        super.setEnabled(enabled);
        if (enabled) {
                getTextField().setEnabled(true);
            if (getLabel() != null) {
                getLabel().setEnabled(true);
            if (getButton() != null) {
                getButton().setEnabled(true);
            setBackground(UIDefaultsLookup.getColor("TextField.background"));
        else {
                getTextField().setEnabled(false);
                getLabel().setEnabled(false);
                getButton().setEnabled(false);
            setBackground(UIDefaultsLookup.getColor("control"));
    public int getBaseline(int width, int height) {
        if (SystemInfo.isJdk6Above()) {
                Method method = Component.class.getMethod("getBaseline", new Class[]{int.class, int.class});
                Object value = method.invoke(_textField, width, height);
                if (value instanceof Integer) {
                    return (Integer) value;
            catch (NoSuchMethodException e) {
                e.printStackTrace();
            catch (IllegalAccessException e) {
            catch (InvocationTargetException e) {
        return -1;
albedo
Postby JIDE Support » Wed Dec 12, 2007 9:04 am
I think you can extend LabeledTextField and just override createTextField method.
