Interuption to look and feel
Postby lukasz.antoniak » Fri Nov 30, 2007 3:45 pm
Hi everyone,
I am quite new to JIDE but I found it very usefull and want to use some features in my project.
I am setting Look'n'Feel manager like this:
javax.swing.UIManager.setLookAndFeel("com.sun.java.swing.plaf.windows.WindowsLookAndFeel");
Than I want to use only JideTabbedPane, so I import only com.jidesoft.swing.JideTabbedPane. But when I look at my menu, the look of some buttons has changed. When I add then to my Jmenu like this:
FileMenu.add(NewFileJMenuItem);
everything is ok. But if I do:
FileMenu.add(new FileSaveAction());
the look changes. FileSaveAction extends AbstractAction.
In this picture we can see normal "New File" and changed "Save".
http://mion.elka.pw.edu.pl/~lantonia/Do ... tmp/sr.PNG
How can I prevent JIDE from influencing on my Look'n'Feel?
lukasz.antoniak
Postby JIDE Support » Fri Nov 30, 2007 3:48 pm
If you just use JIDE Common Layer, you can call LookAndFeelFactory.setDefaultStyle(LookAndFeelFactory.VSNET_STYLE_WITHOUT_MENU) so that JIDE will not mess up with menu related UIDefaults. Yu will not be able to use JIDE Action Framework if you call it but I guess you are not using it anyway.
Users browsing this forum: No registered users and 59 guests
