Having problem in setting DateCombo in Sortabletable cell
Postby raghun » Tue Nov 20, 2007 11:55 pm
I am having a problem in setting DataCombo box in SortableTable cell.
My table contains Date column for which i am using a date combo box,I am setting the cell editor as DateCellEditor, i am getting the date as 27 Oct 1983.
I am unable to format the date in mm/DD/YYYY format.
raghun
Postby JIDE Support » Wed Nov 21, 2007 2:17 am
It is done by DateConverter/CalendarConverter. By default, we use SimpleDateFormat's MEDIUM format to convert a Date or a Calendar to String. You can register your own converter on ObjectConverterManager if you want to change it.
Postby raghun » Wed Nov 21, 2007 4:38 am
I tried using DateConvertor, I am able to convert the date to MM/dd/yyyy format, but it is setting the value in the table cell only once.
Now once the Date is set in the cell ,if now we click on the cell it gives error, because i have set the CellEditor as DateCellEditor and the formatted date that i have from DateConvertor is in String format.
So i am setting String in cell for the first time ,but as i click on the cell next time it gives error because it needs a Date.
Can you please help me formatting a date in MM/dd/yyyy format that returns a Date object and not a String.
As all the DateFormat method's ,SimpleDateFormat("MM/dd/yyyy") and all return a String.........!!
raghun
Postby JIDE Support » Wed Nov 21, 2007 6:44 am
DateFormat's parse return Date. Is it what you are looking for?
Postby raghun » Wed Nov 21, 2007 7:17 am
abc
raghun
Postby JIDE Support » Wed Nov 21, 2007 7:37 am
Sorry but I didn't understand your question. The Date is 11/21/2007. The toString of DateConverter gives you "11/21/2007". Everything seems normal to me.
