JideBoxLayout and Vertical Alignment
Postby tolask » Wed Nov 07, 2007 1:04 pm
Dear All,
I have the following problem.
I add 3 components to an horizontal JideBoxLayout. The first component has the vertical alignment set to TOP... but it's still center-aligned in the panel...
Anybody can confirm this ?
Thomas
tolask
Postby JIDE Support » Wed Nov 07, 2007 3:54 pm
I tried in JideBoxLayoutDemo by setting
button.setVerticalAlignment(SwingConstants.TOP)
to the buttons in that demo. It seems aligned on top correctly. Maybe you try to replace it with BoxLayout just to verify if it is JideBoxLayout problem, or see if you reproduce it in JideBoxLayoutDemo.
Postby tolask » Wed Nov 07, 2007 4:33 pm
You are absolutely right. If I use setVerticalAlignment() it works like a charm.
Actually, I used setAlignmentX() which is available in JComponent (setVerticalAlignment is not, it's only available for some subclasses).
Perhaps the JideBoxLayout should have a look in this property as well.
My 2 cents,
Thomas
tolask
Postby JIDE Support » Wed Nov 07, 2007 4:36 pm
JideBoxLayout should have nothing to do either properties. Does your code work with BoxLayout?
Users browsing this forum: Bing [Bot] and 86 guests
