is it a bug
is it a bug
Postby sunny » Thu Sep 13, 2007 1:02 am
Hi
It is concerned with CheckBoxList which my custom component extends .
I am using 2 CheckBoxList , moving selected elements from one list to another.
First list contains some elements , i shift those contents to second list.
Now if try to remove elements from second list , i am getting ArrayIndexOutOfBound Exception.
I order to temporarily remove this problem i have done this.
public Object[] getCheckBoxListSelectedValues() {
        ListSelectionModel sm = getCheckBoxListSelectionModel();
        ListModel dm = getModel();
        //added by me
         int size = dm.getSize();
        int iMin = sm.getMinSelectionIndex();
        int iMax = sm.getMaxSelectionIndex();
        if ((iMin < 0) || (iMax < 0)) {
            return new Object[0];
        Object[] rvTmp = new Object[1 + (iMax - iMin)];
        int n = 0;
        for (int i = iMin; i <= iMax; i++) {
             //I have added this extra if statement
              if ( i < size ) {
                      if (sm.isSelectedIndex(i)) {
                          rvTmp[n++] = dm.getElementAt(i);
        Object[] rv = new Object[n];
        System.arraycopy(rvTmp, 0, rv, 0, n);
        return rv;
[b]I looked upon the value of other variables..
sm.getMaxSelectionIndex() method return a value higher than the size of model.
If it is bug please confirm , or if i am wrong
All replies are welcome
Thanks-
[/b]
sunny
Postby JIDE Support » Thu Sep 13, 2007 10:39 am
I fixed it and checked into JIDE Common Layer.
Postby sunny » Sat Sep 15, 2007 8:06 am
Hi
If you can tell me what the fix is .
JIDE Support wrote:I fixed it and checked into JIDE Common Layer.
sunny
Postby JIDE Support » Sat Sep 15, 2007 9:06 am
The fix is in CheckBoxList. Yesterday we also had 2.1.3.03 release which inlcudes the fix. Otherwise you would need to get it from svn directly.
Users browsing this forum: Bing [Bot] and 81 guests
