JideTabbedPane - detecting close button click
Postby billesbach » Wed Aug 15, 2007 10:32 am
How do you recommend detecting when the user closes a tab in a JideTabbedPane? How can I prevent the closing?
Background:
I'd like to be able to intercept the closing of a tab in a JideTabbedPane and optionally prevent the closing. This would be useful in the case that the enclosed panel requires saving changes. I can display a Save, Don't Save, Cancel dialog.
billesbach
Postby JIDE Support » Wed Aug 15, 2007 10:35 am
The default close action simply closes the selected tab. But you can set your own calling JideTabbedPane#setCloseAction(). Then you can do whatever in your own action code.
Re: JideTabbedPane - detecting close button click
Postby icemedia » Fri Jan 07, 2011 8:51 pm
hi,
I can do things in the close action but, after that, how can I close the tab?
                    Component b=(Component )e.getSource();
                    b.dispose();
                    b=null;
                    // now the component has disposed but tab is still there...
icemedia
Postby JIDE Support » Fri Jan 07, 2011 9:45 pm
You use delegation. You can get the default close action using getCloseAction() first, pass it to your action and call oldAction.actionPerformed() in your action's actionPerformed.
Postby icemedia » Fri Jan 07, 2011 11:41 pm
thank you for your quik reply, my code is as below:
it seems that I can't get old action (tab.getCloseAction() returns null)
 tab.setCloseAction(new MyCloseAction(tab.getCloseAction()));
class MyCloseAction implements Action{
    Action oldAction=null;
    public MyCloseAction(Action oldAction){
        this.oldAction=oldAction;
    public Object getValue(String key) {
        return null;
    public void putValue(String key, Object value) {
    public void setEnabled(boolean b) {
    public boolean isEnabled() {
        return true;
    public void addPropertyChangeListener(PropertyChangeListener listener) {
        throw new UnsupportedOperationException("Not supported yet.");
    public void removePropertyChangeListener(PropertyChangeListener listener) {
        oldAction.actionPerformed(e);
        //exception comes out here says oldAction is null...
icemedia
Postby JIDE Support » Sat Jan 08, 2011 12:10 am
Never mind. We have a CloseTabAction defined but it is not set to JideTabbedPane's closeAction. It is defined in ActionMap with name "closeTabAction". You can look it up in the ActionMap. Unfortunately in the CloseTabAction, we have this statement.
if (pane.getCloseAction() != null) {
      pane.getCloseAction().actionPerformed(e2);
else {
   // close the tab
So I don't think my original suggestion will work. You can look at the BasicJideTabbedPaneUI.java in the open source JCL to see the code. See if you can find a solution. Otherwise we will have to a veto solution here. We had it already in Docking Framework and DocumentPane where JideTabbedPane was used but not in JideTabbedPane itself.
Postby nick.denton » Mon Nov 21, 2011 9:37 am
I have the same problem. I want to perform a task before closing the tab. So has someone found a solution for that?
Nick
nick.denton
Postby JIDE Support » Mon Nov 21, 2011 12:09 pm
Please try to override JideTabbedPane#removeTabAt(). Before calling super, please prompt a dialog according to the tab index. If it says OK, you could go ahead to call super. Otherwise, just simply return.
