StandardDialog, Windows Vista menu icons replaced by ticks?
Postby chamberlain » Tue Aug 07, 2007 5:20 am
I am using the JIDE StandardDialog in a number of applications. The dialog is used by a number of sub-class dialogs, which are displayed via actions. These actions are used by JMenuItems.
When I look at the menu at startup, the action's associated icon is displayed in the menu perfectly. After selecting a menu item and displaying a dialog based on StandardDialog, the icons are replaced by ticks, like a checkBoxMenuItem.
Does anybody know whats going on here? Is this a known issue with Windows Vista look and feel??
chamberlain
Postby JIDE Support » Tue Aug 07, 2007 8:16 am
It is possible JIDE specific UIDefaults are installed when some of the JIDE components are used. To avoid this, you can call LookAndFeelFactory.installJideExtension(LookAndFeelFactory,VSNET_STYLE_WITHOUT_MENU) when app starts and whenever you switch L&F. I assume you don't use JIDE Action Framework.
Postby chamberlain » Tue Aug 07, 2007 11:42 pm
Fantastic! That works, thanks very much for the tip.
We do not use the JIDE action framework at the moment, we use the Swing Action Manager (SAM). I am impressed with JIDE components however, so that may change...
chamberlain
Users browsing this forum: Bing [Bot] and 81 guests
