by camerong » Thu Aug 02, 2007 6:37 pm
I am trying to customise the tab features of a DocumentPane by setting the close button on the active tab. To do this I tried the following:
1. Extend DocumentPane and implement DocumentPane.TabbedPaneCustomizer. In the customize() method I have the following code:
public void customize(JideTabbedPane jtp)
jtp.setShowCloseButton(true);
jtp.setShowCloseButtonOnTab(true);
jtp.setShowCloseButtonOnSelectedTab(true);
When the code is run the close button does not appear on the active tab but only appears on the right hand side of the tab area as though I had only called setShowCloseButton().
I also tried overriding the createTdiGroup() in the DocumentPane() but this did not work either.
When I call the same 3 methods on a JideTabbedPane the behaviour is correect but it does not appear to work for the DocumentPane.
Could you indicate whether this is a bug or I need to do something differently.
Cameron
camerong
by JIDE Support » Thu Aug 02, 2007 7:31 pm
You just missed one call to disable the default seeting from UIDefault.
jtp.setUseDefaultShowCloseButtonOnTab(false);
by camerong » Thu Aug 02, 2007 8:37 pm
Thanks - that has fixed it.
Cameron
camerong
